profdant139's avatar
profdant139
Explorer II
Dec 20, 2020
Flojet macerator: is it reliable? Maintenance issues?
(I searched the archive for this topic but came up empty. Please forgive me if this has been discussed previously.)
I'm seriously considering a Flojet sewer pump -- several public dumps in our area have closed, and we need to be able to clean out the tanks at home. And my sewer cleanout is just a few inches uphill from my tank valves, so gravity and my old slinky won't do the job.
Yes, the Blue Boy method works, but it is a tedious task to dump a partial load in the tote, dump the tote into the cleanout, rinse and repeat. So I am leaning toward the Flojet as a less-burdensome alternative.
But before I pull the trigger on this expensive item, I want to know if there are any reliability or maintenance issues. This is not an item that I want to play with on my workbench, if you know what I mean.
Thanks in advance for your comments -- I would especially appreciate hearing from those who have first-hand experience.
  • Mine works fine. I don't use it that often, but it's really handy for pumping waste water into a blue boy in the truck bed.
    The only issue I had was powering it. It takes a lot of amps which heats up wires, so I cut off the wires real short and clip them to a garden battery.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Mar 01, 2026
