Salvo wrote:
I suspect the 60C spec for the power supply is not ambient temp but heatsink or case temp.
Your Iota is the only one that has this anomaly. I haven't heard any other reports of shutting down. I know my Iota has been operating at 104F. Perhaps yours is defective?
I'm off to Baja. That environment should test the Iota. Never had it stop in the heat.
Let me clarify, by shut off I mean it stops charging. The fan is still running, there's just no voltage coming from the unit. At night and in cooler daytime temps, this doesn't happen. I called Randy about it when it happened and he verified that was what it was supposed to do when it reaches its upper limit (BTW I didn't buy this from him, it came with the rig, and he offered advice anyways AND didn't try to sell me something). I never read about this either but it seems most people with Iota's don't live where it's as hot as it is here during the summer. As least not as consistently hot. It could be defective by why only defective during 100+ temps (near its upper temp limit) and works perfectly in other temps?
Please give me a heads up when you return. I won't rule out a bad unit just yet.
