coolmom42
May 30, 2017Explorer II
I would skip the insulation underneath, put down 1/2" plywood, and use some sort of cushion material on top. I think the foam will break down under weight of normal use over time. The only thing I would use under the plywood is Reflectix, if anything. Put down some replaceable foam mats in areas you will be walking to keep the floor warmer.
If I were doing it, I would use these foam squares.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
