stickdog
May 30, 2017Explorer
I would put 1x2 sleepers down 12" OC then cut your foam board to fill in between the sleepers 3/8 plywood over that. Your foam wont break down and you'll have support for anything sitting on it. The 1x2's are nominal 3/4x 1 1/2 they should fit between the ribs in the van bed which would for a 1/2 inch foam if you want thicker go with 2x2's and go with 1" foam.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
