fj12ryder wrote:
ktmrfs wrote:
since most cars built since the mid 90's have an RFID key a key copy is useless to start the car. To get a key that will start the car usually means showing registration that matches VIN number, proof of ownership, photo ID a signature and in many cases getting your picture taken and then waiting a day or so to get the key. And in the case of one of my vehicles, they key needs to be programmed to the vehicle either by the dealer or the owner IF the owner has TWO working keys. The programming sequence requires that at the start of the programming you insert one working key,
once that is recognized, it asks you to remove that key and insert a second key. If that is recognized THEN it will allow you to insert the new keys and program them to the vehicle.
So even if someone did manage to get a key to that vehicle of mine, it still wouldn't be programmed and would be useless.
not a very likely way to get a key for a car anymore.
All it took to get a new key made for my 2015 car was about 15 minutes at a key store. Not a big deal if you have the key in hand.
My 97 and 2015 cars with keys are RFID and on both shops and dealers require proof of ownership, and on the 2015 as mentioned above a key from a store even if they copy a key will NOT start the car until it is programmed to the car, which requires at least two working keys or the dealer to program. So someone who trys to copy my keys is SOL, not completely programmed.
On the 97 it is a very rare key shop that can make a working key, dealer can get them overnight and at a reasonable price for a plain non fob key, $15 or so. But they won't order w/o the required proof of ownership they then keep on file and needs to go with the fax for the key order.
I'm suprised that a 2015 car has a key system than can be cut and programmed at a key store w/o additional steps to complete the programming unless they also require and keep info to show proof of ownership.
My 2019 has a keyless go, another story. Haven't tried to get a spare keyless go fob, but the spare key to open the doors etc. is one key shops will make.
