dewey02
Mar 25, 2016Explorer II
tonymull wrote:
I just built a 200w suitcase with the eco-worthy flexible panels. Got the aluminum stock from HD. Made retangular frames with 1" square at top and bottom and 1" L for the sides. Cut to length and the two fit together nicely with self tapping screws. Then I screwed the panels on with same screws (the panels have an aluminum backing). Hook the two framed panels together with a piano hinge, attach a short leg so they can be tilted as needed (doesn't need be long since they lay pretty flat anyway) with a wing nut for adjustment. Easy, took me about 2 hours. 200w, 47 X 22 when closed, and weighs about 15 pounds. Cost me about $450 with controller (PMW) and wiring, and a 20' extension. Actually used some old suitcase handles. The panels come with some pretty sturdy foam padding, these I keep in place with some bungie cord to protect the panels. There is no glass to break and even a pretty deep scratch will not impede them working.
If you've got some photos, I'd appreciate seeing them. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
