- pianotunaNomad IIIBeing "old stock" may be the reason for the low price.
- lawrosaExplorer350 watts just ain't enough for me. I dont use a pure SW for my camper as all runs on mod wave.
I plug RV directly into inverter.
For $100 bucks id rather have more watts. Like the samlex 1000 watt here.
https://www.amazon.com/Samlex-Solar-SAM-1000-12-Modified-Inverter/dp/B004RCQSJY/ref=sr_1_1?ie=UTF8&qid=1520558031&sr=8-1&keywords=SAM-1000-12
But there are features I specifically need, and want for rv purposes that even the samlex does not have. These are considerations some here fail to recognize if you are doing as I do with powering the whole camper.
1.Needs to be floating neutral as this keeps whole camper floating.
2.No GFI as the RV has gfi's already. That would be like plugging a gfi into a gfi.
3. Low voltage, and alarm. The samlex shuts down @10.5v. Underload this may be problematic.
4. Samlex has load based cooling fans. N/G IMO. only 28-32w starts them... uugggghhh!!!
5. Eff. Sam 90% at 50% cont power...
6 warranty. Samlex only 2 year limited..
So with comparison on these features I search for whats in my budget and criteria above and bought a krieger. Corporate in FL and warehouse NC.
http://www.kriegermfg.com/product/kr1100/
Looks like amazon is out of the 1100's at the moment. Can get used, return for 76 bucks.
https://www.amazon.com/Inverter-Installation-included-Automotive-according/dp/B00T564EIY/ref=sr_1_1?ie=UTF8&qid=1520559089&sr=8-1&keywords=krieger+inverter
What I like.
1.Floating nuetral
2.no GFI
3. Low voltage shutdown 10v or less. Audible alarm 10.6 volt.
4. Fans come on thermal/temp based.
5.90% min eff.
6.3 year warranty
7.1100 watt with 2200 watt surge.
8.<.5 amp standby loss
9. THDistortion 10-45%.. Well it is mod sine.
10. usb ports x2.
Ive run testing with microwave, toaster oven, and mr coffee maker.. All work well... TV,s run fine . Box fan a bit noisy on loaw. Charges phones and lab top. Runs my Cpap machine.
http://www.kriegermfg.com/wp-content/uploads/2016/01/KR1100_1500_2000_MANUAL_englishV83017.pdf - SlownsyExplorerFrom my understanding the 350V was superseded by the 375V that I now have installed, the 350v came with cables attached inside the 375V had external post for cables.
Frank. - That is the VE direct line with some phone app to monitor the system remotely.
Look under the Phoenix Inverters 180VA - 1200VA
https://www.victronenergy.com/inverters - pnicholsExplorer II..... Then why isn't a 350VA model shown here on Victron's website: https://www.victronenergy.com/inverters/phoenix-inverter-vedirect-250va-800va
Something maybe doesn't smell right concerning the model on that Amazon link ... or a flat out inconsistency error on part of Victron's official website? pnichols wrote:
12/350 shows right there in the manual and data sheet.
P.S. For some reason, that 350 watt inverter your link doesn't appear to be a regular/current Victron product: https://www.victronenergy.com/inverters
Picture shows optional IEC-320 outlets is all.
https://www.victronenergy.com/upload/documents/Datasheet-Phoenix-Inverter-180VA-1200VA-EN.pdf- pnicholsExplorer IIDon,
FWIW here's the product manual for the the 300 watt inverter I'm using. Notice on page 45 under "PROTECTIONS" that it has reverse polarity protection (an easily replaceable common automotive fuse) on it's DC input side - IMHO a very important feature for an appliance that might get attached many times to a battery during it's lifetime: http://www.samlexamerica.com/documents/manuals/11001-PST-300-12-24-1215_Web.pdf
I don't know about a "nice big fat transformer" being necessary or not nowadays, but my little Samlex is many years old and has been really knocked around a lot. I just use it on various 12V receptacles in the RV and it has performed brilliantly so far.
P.S. For some reason, that 350 watt inverter in your link doesn't appear to be a regular/current Victron product: https://www.victronenergy.com/inverters - pianotunaNomad IIIPhil,
I see it as someone who is getting their first PSW inverter.
One of that person's cons was the size, another was the weight.
Another was reverse polarity protection. I've never seen an inverter with that feature. It certainly doesn't exist for my Magnum.
My only con is the lack of terminals.
Find me another quality PSW under $100 that has a nice big fat transformer? - pnicholsExplorer IIDon ... what's your take on the reviewer's Cons?
- I would have no hesitation with this Victron inverter.
Having RV issues? Connect with others who have been in your shoes.24,302 PostsLatest Activity: Aug 17, 2025
