pianotuna
Feb 21, 2021Nomad III
Bend,
Lead acid batteries do not reach their full capacity until they are cycled 25 to 30 times. This makes the whole test invalid from the get go.
The cold weather test was a joke if you live pretty much anywhere in Canada.
I find it hard to believe that they would not use temperature compensated charging with sensors on the batteries.
What about hot weather testing? Damage on LiFePo4 starts at 86 f, and they should not be charged when the temperature is 113 f.
They also did not test what is possibly the best of the lead acid formats which may be SiO2. SiO2 have a much lower Pukert number than most other batteries.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
