BFL13
Feb 22, 2021Explorer II
My question was not about lifetime cycles, etc, although itinerant1 makes a good point about that for a full-timer. If you only do 50 deep cycles a year, it is not important for $ compared with FLA. LFP with solar full-time has the great benefit of not needing to be fully charged often to prevent sulphation--that is a big deal.
My question is still what is meant by saying you get more "solar harvest" from your same solar set if only you had LFPs instead of FLAs. The solar set can't do any more, but perhaps it means you can restore more AH in the same day with the same solar conditions?
I know about when Bulk ends, etc--we did that with figures I came up with.
I would like somebody else to show his figures and how that would be calculated to show the two "solar harvests" in comparison. Using what exact battery banks in each case, starting from what SOCs at sunrise or whatever the test conditions are. Like that.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
