pianotuna
Mar 01, 2021Nomad III
LiFePo4 can be made to work well. Any battery bank can do that, but for LiFePo4, there are lots of extra hoops to jump through. Such as a way to limit charging from an alternator, a truly compatible converter. There are also high temperature concerns, starting at 86 f and possible low temperature "cut off" depending on the design parameters of the battery management system.
With SiO2 there are few of the above concerns.
Li prices are dropping madly. I would speculate that the DIY crowd are already almost at the point of parity in initial cost for the same number of usable amp-hours in lead acid. I did see an LiFePo4 "roll your own" for $480 using cells with cosmetic blemishes. (Grade B)
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
