pianotuna
Mar 02, 2021Nomad III
Hi Steve,
On the same search I found this:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiawbfU75HvAhVeTDABHYfqBSYQFjAMegQIFBAD&url=https%3A%2F%2Fwww.atlantis-press.com%2Farticle%2F25846169.pdf&usg=AOvVaw2oM6Shas53tE_nwfu5c5NT
"Through experimental analysis of batteries, we draw the conclusion that LiFePO4 battery has a long cycle life, good safety attributes, a high theoretical capacity, low environmental impact and other characteristics; however, it also has many shortcomings, such as need to prevent over-charge, over-discharge, and over-temperature. Otherwise, utilizable capacity of the battery will decrease rapidly, and cycle life will reduce quickly."
Translation: LiFePo4 are unforgiving of any abuse and may bite you in the behind.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
