StirCrazy
Mar 02, 2021Moderator
pianotuna wrote:
Hi Steve,
On the same search I found this:
https://www.google.com/url?sa=t&rct=j&q=........169.pdf&usg=AOvVaw2oM6Shas53tE_nwfu5c5NT
"Through experimental analysis of batteries, we draw the conclusion that LiFePO4 battery has a long cycle life, good safety attributes, a high theoretical capacity, low environmental impact and other characteristics; however, it also has many shortcomings, such as need to prevent over-charge, over-discharge, and over-temperature. Otherwise, utilizable capacity of the battery will decrease rapidly, and cycle life will reduce quickly."
Translation: LiFePo4 are unforgiving of any abuse and may bite you in the behind.
One needs a magnificent battery management system. It is not in my skill set to design such a beast.
who needs to build a BMS. you pay 140 cdn and you have a very good one. if you can wire a battery bank togeather you can build a LFP battery. all your doing is conecting four 3.2V cells togeather with bussbars and you hook the 6 or 7 wires from the BMS to thoes cells.
Steve
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
