StirCrazy
Mar 02, 2021Moderator
KJINTF wrote:
Itinerant1
It's a home brew hybrid Pb/Li system with several different charging parameters and charging sources. A hobby that turned into an obsession.
To date have not removed the Li cells from the RV but have once or twice manually balanced the cells with external loads.
We have several custom modified converters along with DC-DC chargers (just returned a Victron Orion-TR Smart 30amp IMO a POS due to it's lack of functionality, no way to adjust the output current) along with solar.
Always something to keep busy never dull moment
so if I may ask, why did you decide not to put a BMS on your LFP cells. they can be had rather cheel and have active balancing. the one I was refering to is a very high end one that has temparature compensated charging nd all the other bells and whistles including bluetooth.
Steve
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
