Dutch_12078
Sep 15, 2014Explorer III
To put a wrap on this thread, I installed the new PowerMax Boondocker PM4B-45 converter yesterday, and have been checking the voltage readings periodically since then. At first full power up after the initial no load/load voltage checks, the voltage kicked into boost mode at 14.67 volts for about 30 minutes before dropping into normal mode at 13.54 volts where it has remained since, with just minor variances of a tenth or two as the loads change. Since we're actively living in the motorhome, I don't know when or if I'll see it go into float mode at this point. All signs of the erratic voltage readings I saw with the OEM Magnatek have disappeared, and I think I detected a bit of a smile on the batteries. :W
My thanks to everyone for their input!
