enblethen
Jan 18, 2020Nomad
Ford starter is energized by the starter relay. Power to the starter control circuit and under dash fuse block comes off the large post on the relay. Ford uses fuse links adjacent to the relay to protect the wire. Ignition switch when turned to start position applies power to the coil.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
