MrWizard
Jan 18, 2020Moderator
Ford start relay has NOTHING TO DO WITH battery charging
Chassis or house
In your case, The charge relay is only wired to the "run" side of the ignition, and only active when the key is in the run position, it might even be tied to the fuel pump relay circuit and only active with engine running
On the start mode of the ignition it does not engage/activate
Or you would not have needed to use that long jumper cables
Chassis or house
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
