DrewE
Jan 19, 2020Explorer III
On my motorhome, the combiner solenoid is activated from the "run" position on the key, so it does combine if the key is in run but the engine isn't running--the same situation where the fan blower operates, etc. (It is also activated by the emergency start button on the dash, which is actually a SPDT switch. When pressed, it connects the control wire of the solenoid to a house battery circuit; when not depressed, it's connected to a chassis "run" circuit.)
There are of course any number of minor variations on how these things are set up by different manufacturers and with different models.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
