BFL13
Jan 20, 2020Explorer II
PatJ wrote:
On my 2019 Ford C the charge isolator relay is under the coolant overflow bottle. It has a delay built in so the engine has to be running for about 20 seconds before it ties the chassis battery and house bank together. The manual explains it needs to see charging voltage >13.6V on the engine side which starts the 20s timer. Any time voltage on the engine side drops below 13.6 it will untie the batteries and wait for 13.6 again to restart the timer. You can hear this click from the driver's seat after starting the engine. Emergency start switch bypasses this delay.
From a post in thread in another forum that I linked earlier:
"I run a dumb solenoid wired to come on with the ignition (not a fancy IBS system - which is just a dumb solenoid with a little brain to decide when to energize the solenoid). Done deal"
So the 2019's come with an IBS OEM?
EDIT--how is that 20 sec delay better than just waiting for the spring-loaded key to go back to "ON" from "START" ?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
