Skibane
Apr 25, 2022Explorer II
Suggestion: Go with the cheaper OEM option, and use the savings to also install an OEM replacement fan clutch.
Typically, as it ages, a clutch loses some of its ability to couple the fan to the drive pulley - so you get less fan speed, and less air flow.
A lot of aftermarket fan clutches don't work nearly as well as the original - so an OEM replacement is the way to go.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
