MEXICOWANDERER
Apr 25, 2022Explorer
If "fit" is an issue, check fin count per inch. I went to a 5-row count 32 find per inch in a massive increase for a radiator that sits at a 45° angle under my bus. But I had encountered 122° outside temperature on two occasions. The NTC Cummins engine has had no problem achieving 180° coolant temperature near freezing temperatures.
Some knotheads designed radiators with rows all in a line. Good radiators place added rows in a staggered fashion. Adding higher fin count and staggered tube count really oopmps the cooling capacity without the need of changing tanks.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
