K_Charles
Jul 09, 2013Explorer
Your link says
Caster Specification: 4.5º
Measured caster angle: 3.5º (out of spec?)
Frame angle: 1.0º (up in rear)
Corrected caster: 4.5º (3.5 + 1.0)
Change required: NONE
spec should be 4.5 but measured "out of spec" at 3.5
If you correct it with the frame angle then there is no change required.
In that example thay took the frame angle into account when they set the caster.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
