BruceMc
Jul 09, 2013Explorer III
I considered frame angle when I took mine in to be aligned. Lots of folks here say to load the MH as you would for normal travel - I took the opposite approach, and made sure it was as empty in the rear as possible, and the air bags and rear tires were inflated to their maximums. Then once it was aligned with that frame angle, any loading would add positive camber.
For some reason, Four Winds decided the far aft end and across the back was the best place for a water tank....
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
