ksbowman's avatar
ksbowman
Explorer II
Feb 28, 2017
Framework in nose of 5th wheel
I had a light cover come off and leak water into the nose of my Keystone Outback. The filon delamed on that side below the light, not too bad but I look at it everytime I look at the nose. I am going to pull the filon off and replace it and want to have an idea of what to expect when I open it up. It is aluminum frame and I may add more framing if I feel it requires it. Anyone? A picture of any brand would be appreciated.
  • ksbowman wrote:
    Biscuit, Is the 5th wheel shown opened up your? Do you know what the problem was that required the nose to be removed? Thanks, Ben
    NO!
    Not mine
    Pictures are from goggle search....5th wheel front cap removal water damage
  • Biscuit, Is the 5th wheel shown opened up your? Do you know what the problem was that required the nose to be removed? Thanks, Ben
  • Even with an aluminum studding the front/rear caps and roof trusses will be wood on trailers
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
