docj
May 28, 2013Explorer
Bill.Winegard wrote:During the sleep period it completely stops charging the battery as a way of reducing water loss.
That appears to be what our new inverter does as well. While I don't see any documentation as to time, it does go into a state where it shows 0.0 amps of charging. Then, from time to time it kicks in at some random rate but never the full 150 amp which appears to be a step higher than float. We have AGM batteries so water is not an issue but I think this charging pattern will provide a better overall experience than our old 458. I do know that the new 150 amp charger and the way the charging cycles are handled, substantially reduces the recharging time when we are dry camping.
It's pretty clear that electronics have made significant strides in the past decade. Another thing I noticed about my new unit is that if you have the charger off for any reason it starts back up with a minute or two of rapidly ramping the charge rate up and down from zero to 150A. I think what it's doing is determining how the batteries react so it can then select an appropriate charge rate, rather than always starting from bulk charge and going forwards from there like the old Freedom 458 used to do. As you said, Bill, these little things should improve overall battery performance and lifetime.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
