TechWriter
May 29, 2013Explorer
docj wrote:
The replacement of the Xantrex by the Magnum was easy; the form factor for both is about the same and the connections are in roughly the same locations so existing cable lengths worked. The Magnum's remote panel uses the same telephone wire and RJ connectors so I could use the one that was already in place.
X2 -- but I replaced my Freedom with a Magnum MS2000. The fact that you can use the same remote control panel wiring was icing on the cake as I had no desire to run wire.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
