missncajun's avatar
missncajun
freezer drain tray drips into fridge
I have model Dometic RM1350. The freezer drain tray drips into fridge. It drips from the spout that goes into the drain tube to the outside. I've checked the drain tube and it is clear to run but the water flows down and around the spout before going into the drain tube. Is there a gasket that should go around the spout?
1 Reply
  • Are you getting water at the bottom of the fridge on the inside? Or are you getting water on the outside behind the access panel?
