Rock2's avatar
Rock2
Freezer has not reach down to zero
I have Norcold - Model # N821FLT. Refrigerator temp works fine 40 degree but freezer has not reach down to zero. I increased setting from 4 to 8 last night. I use Multimeter Clamp to test heating tube. It came out between 1.2 and 1.4 AMP. I would think the heating tube works fine? Made me wondering if it is time to replace heating tube? Any advise would be appreciated. Thanks Advance?
  • MrWizard wrote:
    How cold the freezer is decides how hard your ice cream is
    We like our ice cream around 5-10 degrees . Good scooping temp.
  • I replaced my 12 year old Domestic 2862 a month ago freezer varies during the day between -1 and +4. The lower box stays in the 39-40 range this is on AC.
  • 112V AC Power............low voltage plus you have very low Amp on element
    20*F in freezer and 40*F in food compartment.......NOT cooling properly
    Swap to Propane.
    Replace element.
  • Trackrig wrote:
    Why does it need to reach zero? We keep ours between 15 and 20F.
    Bill
    IMO that's WAY TOO WARM or something is seriously wrong with your refer. A properly working refer in temps up to around 100 should be able to keep the freezer temp below zero IMO.
    If not then there is either a baffle installation issue or partially blocked boiler tube.
    Larry
    Bill
    How do you control freezer temp?
    Food section is only compartment that has a temp sensor and that is what thermostat uses for controlling........food compartment temp.
    Freezer by design gets as cold as possible..which should be 5*F or lower on a properly functioning absorption fridge
  • hehehe
    Come down here and try to gain 0F. The only valid food storage temperature recommendations are those findings as publicized in USDA Food and Drug recommendations.
    A two day jaunt is vastly different than 3 or 4 weeks food storage. Bacteria multiply to the square of given time DEPENDENT on temperature. Lower temperature buys time. I have multiple refrigerators. With milk of the same expiration date, 36 versus 44 degrees resulted in the 44 degree milk going sour in six days. The 36 degree milk was like fresh. Both refrigerators otherwise were empty. The milk remained dairy sealed.
    Frozen vegetables last longer at -5F than they do at +10F.
    Freeze one batch of ice to -5F, the second to +15F, put five cubes from each in an 8 oz glass, fill the glasses with identical batch water, wait 5 minutes then see
    The temperature of the liquid
    Compare the size of the ice cubes
    Physics is unforgiving.
  • MEXICOWANDERER wrote:
    hehehe
    7 yrs FT our Dometic maintained 5*F or colder in freezer and 38*F in food section routinely.
    Never had any 'food spoilage' issues.
    But then again our Dometic fridge was properly installed with the correct clearances so that the natural draft airflow was provided
  • My Norcold was installed by a Norcold Warehouse Distributor and Manufacturer. Horrible cooling. Then after trading Sal at Kool Fun for a new Dometic, it acted the same. So I upgraded to a Norcold with ice cube maker.
    After multiple D cell fans, and four 80 cfm fans were installed against the condenser (one to aid flue convection) that dropped temps 4 degrees. But food still spoiled. This was over a 5-year period and the last trip was the last for gas refrigeration. The only gas device that worked correctly was a Dometic FC-140 chest freezer. But 1.5 CF of storage was almost a joke.
    I returned to Q.R. in 1990 with Vestfrost and the difference was humiliating.
    Quintana Roo temps sometimes reached 117F inland. Mostly 105 - 110F on the beach with dripping humidity. I celebrated by cranking the freezer down to -10F but the ice cream needed to be warmed up. Packaged broccoli and corn and thick cut steaks (plus tubs of Rock Road ice cream and butter) lasted 6 months in Mexico, four months in Guatemala and then a return to the USA where I came down with AML, acute myleogenic leukemia.
    Food storage depends heavily on length of time desired. A 45 degree refrigerator can laugh off a gallon of milk over a period of three days. But toxic stuff like cut meat is dicey at best.
    And while people toke ammonia and fret over ruined vacations, I have better things to do. One of them isn't chucking prematurely spoiled food.
    Keep In Mind!
    A refrigerator or freezer temp that meets FDA temp guidelines is perfect. My issue included being several thousands of miles from home and spending a fortune driving a hundred miles to replace spoiled food. Top that with chew and spit lifespan and for me the choice was inevitable. Five hundred dollar cooling units do not turn me on. Try finding block ice down here and try NOwhere in Guatemala.
