Any ideas as to why the freezer would start getting so cold that the food inside bags have started icing up. Have cut it down as low as possible without causing refrigerator from getting to warm.....H...
The freezer CANNOT get too cold. The normal range of a freezer is 10 degrees to -10 degrees. The temp sensor on ALL RV absorbsion refers regulates the regular refer NOT the freezer and there is NO temp adjustment on a RV freezer. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
