ksg5000
Sep 30, 2019Explorer II
Make sure the humidity switch located in the door jam isn't turned on - that provides power to heat tape which may eventually impact cooling capacity - also make sure your fridge light bulb is turning off when you close the door. Make sure there is adequate air flow behind the fridge. Also suggest you use YouTube and check burner orifice and baffle. If all that doesn't fix issue then it's possible you have partial blockage of the cooling unit - that usually is the beginning of the end but there are temp fix (google).
