Scovndrel
Sep 30, 2019Explorer
Old-Biscuit wrote:ksg5000 wrote:
Make sure the humidity switch located in the door jam isn't turned on - that provides power to heat tape which may eventually impact cooling capacity - also make sure your fridge light bulb is turning off when you close the door. Make sure there is adequate air flow behind the fridge. Also suggest you use YouTube and check burner orifice and baffle. If all that doesn't fix issue then it's possible you have partial blockage of the cooling unit - that usually is the beginning of the end but there are temp fix (google).
OPs Model does NOT have that feature.
Thank you for saving me the time I would have spent searching for that. Pretty sure I don't have a light bulb either. Will double check next time I go out there.
