wrgrs50s
Jun 01, 2018Explorer
dougrainer wrote:wrgrs50s wrote:
I had a friend with a similar issue and he removed his fridge and turned it upside down overnight then flipped it back up the next day and it dislodged the blockage and all worked fine afterwards. Worth a try if all else fails.
That's like turning yourself upside down to remove a blockage on your Arteries. The blockage HAS to go somewhere. But, this is just a dig at you. Cooling unit blockages CANNOT be broken loose or removed. They are as hard as a WELD and ATTACHED at the upper metal lines. If you have a partial blockage you can "Burp",(turn upside down), and move the ammonia around. Or, you can just let the unit sit OFF for a few days to accomplish the same thing. ALL this does, is allow the unit to cool again. BUT, it will NOT cool as efficiently as an unblocked unit. When it gets HOT outside the refer will not keep up with the demand for cooling. Doug
I understand what your saying Doug, I don't know how it works on some and not others, but it's worth a shot if your an old poor boy.
