dougrainer
Jun 10, 2018Nomad
30sweeds wrote:dougrainer wrote:wrgrs50s wrote:
I had a friend with a similar issue and he removed his fridge and turned it upside down overnight then flipped it back up the next day and it dislodged the blockage and all worked fine afterwards. Worth a try if all else fails.
That's like turning yourself upside down to remove a blockage on your Arteries. The blockage HAS to go somewhere. But, this is just a dig at you. Cooling unit blockages CANNOT be broken loose or removed. They are as hard as a WELD and ATTACHED at the upper metal lines. If you have a partial blockage you can "Burp",(turn upside down), and move the ammonia around. Or, you can just let the unit sit OFF for a few days to accomplish the same thing. ALL this does, is allow the unit to cool again. BUT, it will NOT cool as efficiently as an unblocked unit. When it gets HOT outside the refer will not keep up with the demand for cooling. Doug
Doug...Right and wrong. the blockage material will always remain in the system but may move around depending on what it is. Rust,weld residue,ammonia crystals,who knows. Flipping the unit DOES work! The last old MH I had...unit was flipped and the fridge worked perfect for !7 YEARS. Several other ones the same before that. I'm sure it's not a 100% deal but definitely worth a try.Let's see...free vs $1000 or more.Cooling unit alone,5,6 hundred.
My method-Flip for 1 day,upright 1 day flip 1 day,upright and so on for 4 or 5 days.
YOU ARE ABSOLUTELY WRONG. I suggest you do a Cooling unit rebuilder search and they have pics of the upper coil cut in half showing the HARD WELDED blockage. I have 38 years experience as an RV Tech and extensive training by both Dometic and Norcold, and I always remind people if burping was a solution then Norcold and Dometic would utilize burping as a field fix instead of replacing the refer or cooling unit under warranty. Which they do not. If you BURP a unit and it is FULLY restored, you did not have a blockage. If you have a partial blockage you can indeed burp, but it will NOT restore the complete cooling operation. It may work, but when it comes time for 100% operational cooling in warmer weather, the refer will not perform as it should. Doug
