time2roll
Oct 23, 2014Nomad
Frost on the exterior does not indicate the propane is frozen. Needs to be about -40 just to get propane to a liquid state. You will never see solid frozen propane.
Although in cold temps the propane may boil so slow it will not provide enough volume to run what you ask, especially a generator working hard.
Keep the tanks full and consider an electric heat pad if you will encounter these conditions on a regular basis.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
