Born2RV's avatar
Born2RV
Freightliner M2 won't start...
2007 Freightliner M2 Business class, Allison Transmission, MBE9000 engine... won't start. Error codes: ICU140, ECU128, Ab5136.
Found blown fuse for bulk head module and replaced it. Turn key, dashboard lights up, fuel gauges flip/flop, radio lights up but does not work, truck won't start. 2 batteries about 2 1/2 years old.
Thanks for any advice that prevents me from calling for a tow truck.
  • Thanks for the advice... particularly the Escapees Forum.. Believe it or not we found the solution - new batteries. Replaced the 2 year, 11 mo, 2 week old batteries with brand spanking new ones and waaaalaaaa started right up, sounded like a new truck. No error codes. It is almost oil change time so I will have it checked at Freightliner.
    Thanks again, I appreciate the advice.
  • It's tough finding anything of value. When was the last time you had an ECM readout?
    Escapees has a good MDT forum:
    Escapees MDT forum
    I think you should make that call.
  • I looked those up.. not much help.
    From the justask: "136 fault is for a abs fault. This means there is a fault in your abs system. 140 fault is for your instrument cluster unit"
    I feel for ya bro. Had a bit of trouble starting my M2 Cummins ISC 8.3l.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 08, 2025
