Sort By
- Dutch_12078Explorer II
rk911 wrote:
but the cheap ones don’t reduce the pressure, just the flow. do yourself a favor and buy a quality Watts water pressure regulator. check your favorite home improvement store ir online at The RV Water Filter Store.
I do agree that a quality regulator like the Watts series is the best choice, but I'll also note that the "cheap ones" like the Camco barrel regulators, do indeed regulate the pressure properly. I've tested several of them using before and after gauges, and while they may not be as accurate as a Watts, they do get the job done they're supposed to do. If they simply reduced flow, there would be all sorts of complaints about them since the pressure would still reach the incoming line pressure when there was no flow, possibly blowing out fittings or hoses. - rk911Explorerbut the cheap ones don’t reduce the pressure, just the flow. do yourself a favor and buy a quality Watts water pressure regulator. check your favorite home improvement store ir online at The RV Water Filter Store.
- beemerphile1ExplorerAmazon, Camping World, virtually any RV dealer
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 13, 2025
