Hankjoe
Oct 19, 2017Explorer
Solved - Thanks for general advice - it solved on its own - We filled up tank pumped (hand pump from the fill area. We knew the water pump in general worked as it would pump water from a pail.
We thought about removing the tank & cleaning, but decided to empty tank again (using the trusty hand pump) When we pulled out the hose a little slime came with. We santitized the system. and filled it all up again. The faucets had water coming out & water pump would shut off, And, we could now drain the tank.
The water pump pumps water, shuts off and we can drain the tank. We have winterized. I believe what happen was "stuff" slime or whatever caused the problem. Hopefully it's cured for good.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
