Ralph_Cramden
Nov 12, 2018Explorer II
Braces wrote:
LIPPERT probably put in what Cedar Creek designed and required of them. How do you know to blame Lippert?
If you are referring to my post and you would of taken the time to read it and clicked the link, you would of seen the water tank frames that are a standard Lippert part made in different widths to fit different tank sizes.
Cedar Creek may have specified something different or they may have installed supports themselves. Typically though when a manufacturer uses Lippert frames, chances are they came with the Lippert supports already installed by Lippert. The same goes for the spreaders that the black and grey tanks hang from.
This is what happens to the Lippert support trays. Eventually the angles from frame rail to frame rail would of deflected enough until the tabs that the bottom cross ties fit into would of popped out, then out drops the tank.
Hanger I fabbed on left, Lippert on right.
Replaced with real angles
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
