- tvman44ExplorerFill them with water and add Rid-X and let sit for a couple of days. Works for us. :)
- DutchmenSportExplorerDo you drive with water in the tank? If not, fill it about half way, drive around a little. See if the sloshing will help clean them off. It's also possible the sensors could just be going bad or the wiring is going bad. Try filling and drive around, then drain and see if there's a change. This is definitely the least evasive attempt at a solution.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
