Clay_L
Jun 25, 2016Explorer
If you are in the city fill mode the pump may run and pump water from the fresh water tank. If the pump is on and the shore water pressure is lower than the water pump cut-in pressure it will run and take water from the tank.
At one RV park that we spent all or part of the winter in for several years, the water pressure varied from 20 psi or so up to about 35 psi depending on whether the well pump had just pumped the well pressure tank up and the number of users. When we took a shower we always turned the pump on so we had a decent pressure when the shore pressure dropped.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
