Lynnmor
Sep 06, 2019Explorer II
Lantley wrote:
My set up does not gravity fill. You can fill via a pressurized water hose or via a bucket using the on board pump. Filling is not a problem. I have a 80 gallon fresh tank,filling via gravity would be a PIA.
My overflow and vent tube both exit beneath the fresh tank.If you overfill the fresh tank a siphon will/can start. Once started the siphon can dump a lot of water on the ground.
iIhave resolved this issue by installing valves on my drain and siphon lines
We need to quit calling a spill a siphon. The vent hoses are attached at the top of the tank and go down towards the road. If the trailer is tilted, water can spill out. If you round a curve and the water sloshes to the vent side, it will spill out. A siphon requires that the hose extend down into the tank, but that is not how they are made.
Adding valves to vents is both a miserable way to deal with a water system, and major damage can happen if one ever forgets to open them.
The proper fix for this cheap factory shortcut is to route the vent hoses up and out well above water level.
Related Content
- May 26, 2013Community Alumni
