steved28
Sep 10, 2019Explorer
Lantley wrote:
My set up does not gravity fill. You can fill via a pressurized water hose or via a bucket using the on board pump. Filling is not a problem. I have a 80 gallon fresh tank,filling via gravity would be a PIA.
My overflow and vent tube both exit beneath the fresh tank.If you overfill the fresh tank a siphon will/can start. Once started the siphon can dump a lot of water on the ground.
iIhave resolved this issue by installing valves on my drain and siphon lines
This doesn't make any sense. If it allows a siphon, no matter how, it is no longer a vent, it is now a drain. Any vent should be above the water level, regardless of where the vent pipe may lead after that. Who on Earth would put a vent below the waterline???
Related Content
- May 26, 2013Community Alumni
