Fisherman
Oct 23, 2020Explorer
Roger10378 wrote:
The 1-1/4 in line would be the gravity fill on most of the older trailers. Do you have a gravity fill? If so my guess is that the tube has become disconnected.
I really doubt the line is disconnected otherwise the flood would be inside the trailer. More likely is that the fresh water holding tank is under the bed or similar place where the outside location of the fill point would prevent installing the fill point without having the hose visible through the wall inside. My fill point is about 2 inches above the tank, just under the sheet of plywood on the bed.
Related Content
- May 26, 2013Community Alumni
