Ricky_R's avatar
Ricky_R
Fresh Water Tank Overflowing When Turning
My rig is a 2019 (but recently bought new, never used) Jayco 27SGX fifth wheel. I left the campground today, after our first trip, with 1/3 level in my fresh water tank. I noticed water pouring out onto the road whenever I would turn to the left. I pulled into a large parking lot and had my wife watch while I made a left turn. She noted water coming out of what appears to be the fresh water tank vent located at the passenger side rear of the coach. There are two lines here, one is around 5/8" diameter water hose, and the other is around 1-1/4" corrugated plastic hose with a flattened rubber boot attached. The water is coming from the larger line with the boot. So...is this normal? Is there something that I should be doing to prevent this? It does not make sense to me to fill the fresh water tank, then have the water that you need spill out at each left turn.
Thanks for any helpful replies.
Ricky R
  • The 1-1/4 in line would be the gravity fill on most of the older trailers. Do you have a gravity fill? If so my guess is that the tube has become disconnected.
  • bukhrn's avatar
    bukhrn
    Explorer III
    My class c does it, but not with only 1/3 tank, only when it's full.
  • I had a similar thing happening, and it also happened when parked on a steep hill.
    I extended the overflow vent line about 15" above the top of the tank, and then down to vent out the bottom of the MH. I used a flexible CPAP hose. It stopped the problem.
  • Thanks for all of the quick replies. I just thought that there may have been something I was missing, this is our 5th fifth wheel and we have never had any issues with any of the others. I agree with TenOC, poor design, I will look at DIY modifications.
    Thanks,
    Ricky R.
  • We had a North Peak 5th wheel in which the vent line was routed so that we would lose three quarters of our freshwater on a trip to the campground. When we complain to North Peak they said that's the way they do all the vent lines. Not much help.
    We capped off 1 of the vent lines (On the driver side) and rerouted the other vent line to the vent located in the fill line. This solved the problem.
  • I agree with Fisherman's resolution and cause, but ours has never done this. We have an overflow vent, in fact, we fill till we hear it "burp" and have never had it spill like described. Seems to me to be poor design, unless that's a Jayco thing, the vent that is.
  • It's one of those thing called centrifugal force. A full coffee cup with no lid will spill if you apply the brakes. Same thing. Go get a tapered wine bottle cork, put a stainless screw in it with a short piece of string and insert it into the fill port. Problem solved, mine does the same thing.
