jterr
Dec 12, 2017Explorer
Fridge ??
Just bought this 2004 and fridge was working, decided to take out on a 1st run camp trip fridge not working. It is a Danetic?? and has power ,when switched to gas can hear gas lightup. All fuses good....
enblethen wrote:
Do you have the owner's manual for it?
One thing on gas that can effect the cooling is a clogged stack. It is a 3/4 pipe inside the stack on the right side of the exterior access. Try cleaning it. From the bottom, using a stiff wire about the size of an old metal coat hanger. In the pipe about 4 inches up is a baffle. Push the wire up into the pipe and try to rattle the baffle. Many times there will be some carbon falling down. Vacuum it out.
What happens when you try using the 120 volt mode?
Price is way to high for a full replacement. If it is a cooling unit, you should find someone to replace for around $700.
