jterrExplorerDec 12, 2017Fridge ??Just bought this 2004 and fridge was working, decided to take out on a 1st run camp trip fridge not working. It is a Danetic?? and has power ,when switched to gas can hear gas lightup. All fuses good....Show More
fairway2002ExplorerDec 13, 2017Make sure unit is level. Test temp of burner. I used this replacement in last rv. Worth $150 installhttps://rvcoolingunit.com/Dometic-Cooling-Units-remanufactured-C4380.aspx?sid=298If you put new cooling unit. Replace waterline and add fans in chimney
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
Related ContentTroubleshoot fridge problem...Norcold Model 611 Fridge problemDometic Servel RGE400 fridge too coldDometic 2-Way fridge repair issuesNew Fridge, Old Coach
