Just bought this 2004 and fridge was working, decided to take out on a 1st run camp trip fridge not working. It is a Danetic?? and has power ,when switched to gas can hear gas lightup. All fuses good....
Your refer needs 12 volts DC to light, the stove does not, so it is operating properly. Run it on propane for short time maybe a couple hours. Then feel the cooling pipes to see if they are warm or hot. That would be indication that cooling unit should be good. If they are warm on hot, tap the lower portion where the cooling goes into a horizontal bulge. Not to hard! Listen for gurgling!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
