BFL13's avatar
BFL13
Explorer II
Oct 31, 2018
Fridge Electric Lamp But N0 120v
Just found out the hard way, that the 1991 2-Way fridge we have (Servel brand) when switched to electric still shows the lamp even when the 120v not on. The lamp is 12v of course.
So we thought it was working ok even though the 120v had been lost, until it was opened and found to be not cold inside.
I don't know if that is normal for these fridges, even the new ones. The 2003 Norcold we had in the 5er had a "code" showing if you lost 120v to the fridge, which is what you want as a warning.
So if you have a fridge that does not show codes, be worth checking to see if that could happen to you. If so, maybe have to invent your own alarm, like a 120v lamp in the same circuit as the fridge 120v receptacle's.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
