RV_SamExplorerJun 22, 2016Fridge Gas to 120VACOur fridges for most part run on 120VAC and kicks over to gas if power goes off. Has anyone made up a circuit to do this the other way around ? Thank you.
time2rollNomadJun 23, 2016With an auto-change regulator you should not run out even for extended use.If propane seems to go fast you may have a leak.I assume the RV is in storage keeping the beer cold and propane is lower cost than electric.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related Contentgas fridgeNorcold Model 611 Fridge problemTroubleshoot fridge problem...Norcold gas & electric fridgeResidential vs Gas/Electric Fridge?
