joshuajim
Oct 10, 2014Explorer II
ashnic wrote:
Thanks for the great info..I am pretty handy but have never pulled a fridge..is it that difficult?
Not real difficult.
Remove the outside cover to the fridge, disconnect gas line (make sure tanks are off), loosen 2 screws where 12V connects at the bottom (check color coding and/or mark them before disconnecting). Unplug 110v plug.
There are 2 screws in the "tracks" at the bottom into the plywood floor. Remove then go inside.
Remove the cover with the eyebrow controls. It pretty much just pulls straight out. Two screws up into the trim above fridge. Remove trim at the bottom, again it just pulls straight out and remove 2 more screws.
There could be screws at the side going into the trim beside the door.
Go outside and push gently. It should move inward a little bit. This is where it gets a little tricky. Go inside and create some type of platform for the refer to slide out onto. I use an old tub with a piece of plywood that matches the height of the bottom of the fridge.
Grab the fridge and slide it out onto the "platform". Takes me about 10 minutes to remove one.
Reverse to install.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
