We overloaded our generator and while the genny was running, nothing was working. Simply hit the reset and everything worked- except the fridge & furnace. Found a blown fuse, replaced it and the furna...
Thank you everyone for your suggestions. Turns out a fuse on the panel was mislabeled as a spare! The label said the fridge & furnace were on the same fuse. We got the furnace working but no fridge. Before tackling the black box, etc., we decided to check the other fuses and the one for the fridge had been labeled as a spare. Easy fix and problem solved. Thanks again.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
